Good morning everyone, we recently purchased an 89 four winns 205 sundowner with a 5.0 ho omc, model #502APRMED. Only put about 3-4 hours of actual engine run time on it since we've gotten it, we like to launch go to our spot and start relaxing and drinking :joyous:
Anyway the temp gauge never reads over 100, except when the impeller broke and it got up to 160, this was kind of my test if the temp gauge actually worked.
Oil pressure seems high to me, always near 80psi, probably closer to 60 when idle and slow and 70 when on plane. I looked in the manual and couldn't find the recc. oil pressure so maybe its fine.
My thought is thermostat stuck open, keeping engine cold thus keeping the oil thick and pressure up. (marina said to and used SAE30 on it)
Replacing the thermostat according to the book looks pretty easy, they say to remove the hoses take out the two bolts, pull apart, clean, and replace rubber o ring, thermostat, and the gasket.
Am i missing anything here, any other points of view that i may be blindly overlooking?
Thanks!
Thanks!
