Re: Cobra Stern Drive Taking On Water
I took my cobra drive off and removed the bellows.The way mine was attached was,on the side to the drive it had a big spring retainer inside it that held it in a grove,you will see this when you pull drive off.On the end closest to transum it has a big stainless steel screw clamp.By the way,it isn't hard pulling cobra drive.I lowered the bow of boat down so the stern is higher.I lowered the drive down so the skegg set on a piece of plywood.Follow book on removal,pull and wiggle drive and it will slide out.I did mine by myself,figure it weighs about 90 to 100 pounds,I was able to pick mine up and care it.I built me a frame out of 2x4s with rollers under it and set drive in it and rolled it away.Follow the manual and it isn't a hard job.Also the exhaust bellows as stated above, that you buy will have slots in it along the bottom,which might make you think it is defective.That is how they make them now.Hope that helps some.
