Boomyal
- Aug 16, 2003
- 12,072
I'm finally back on my floor restoration project, almost full speed ahead. I finished the tear down and now am starting to prep everything necessary before floor and foam. <br /><br />I'm going with my original mahogany stringers, with only slight deterioration, and will saturate them in CPES. The only parts that I will replace are the 2 x 8 top caps on my motor mount stringers. I will also fill the 4.5" void (originally foam filled) between the outboard stringers and the main 3 x motor mount stringer, with laminated and CPES'd fir 2 x 6's.<br /><br />Would it be a good idea to coat the entire inside bottom of the hull with a coat of epoxy resin? The large weave hull fabric appears fairly well saturated but you can feel signifigant texture from the weave. If polyester hulls have any tendency to weep, it would seem to be a good idea to give it one coat of epoxy, to seal it.<br /><br />What do you think?<br /><br />ps. sorry I put this in the wrong forum.<br /><br />
