Hi. New here and new to my Chrysler 7.5HP 1980 model 72h0c engine.
I want to take a look at the pump impeller, as the tell-tale is not producing much water. I tried to remove the lower leg, but saw no way to release the shaft to pull it all the way off.
Can someone please let me know which part number in the linked diagram should I be removing to get to the impeller. Also, if there is a hex nut or something to release the lower leg or gear housing, where should I see it.
DIAGRAM fom the manual on Boats dot net is linked below
MANY thanks for friendly advice.
