Hey all,
Next problem that has been causing me issues. So when i crank the engine the starter turns the fly wheel slow like a dead battery. Things i have tried so far.
1. replaced the starter
2. replaced the cables from the battery to the motor
3. Replaced the ground wire from ground to solenoid
4. replace hot wire from hot side solenoid to the terminal strip
5. replaced the cable from solenoid to starter
6. replaced solenoid
7. used fully charged battery
8. without the plugs it cranks like a champ.
So any advice would be fantastic.
Thank you in advance
Bob
Bob
