Playtime01
- May 29, 2009
- 14
Runs great for an hour and then stalls and lots of trouble keeping it running and eventually it won't start at all. Water pump is working, head is cool. It is getting gas to plugs. Seem to get wet when the trouble starts to happen. Carb is fine. I'm thinking the ignition coils are maybe getting hot and giving a weak spark causing plugs to foul. What do you think? When could I get a set of coils for a 1982 Chrysler 15 hp outboard anyway? Points are set right. Could the condenser cause this problem? Plug was suppose to be a L4J Champion. A marina told me to use a NGK BR6HS but now after reserching it I think I should be using a BR7HS or a L82C Champion. Is this right? Any help would be appreciated. Thanks.
