gm280
- Jun 26, 2011
- 14,597
I presently have my 98 Blazer with the 4.3L V6 engine's intake removed. It was leaking water and I bought the new FelPro gasket set to replace the older ones to stop the leaks. And as usual, when I do things like this, I completely remove and clean everything to like new again. And that also means I am presently cleaning the spider injectors tubes as well. Not an easy thing to do but I take it slowly and clean everything. However, I see that there are aftermarket and even GM built MFI replacement for the CSPI spider on the market.
My question is, has anybody made the swap and if so does the engine run better and increased gas mileage? I read folks changing to the MFI spider and gaining better fuel economy on top of the better performing engine. So anybody want to chime in whether this is a plus or not. It is basically a $250 swap. What would you do? :noidea:
