Ok guys
I changed the oil in my bayliner. OMC cobra drive.
basically I opened the small plug at the bottom of the drive right by the bottom fin. let it drain for 1 day. opened up the top cover where the dipstick is and filled it up. let it sit for a couple of hours and filled it again. I let it sit overnight and then filled it again 2more times. When i filled it it didnt take a ton but overall it took something liek 4 quarts or so. i dont really know cause i was using a 1 gallon can.
Either way I let it sit until it got to the point where the oil level wouldnt drop anymore . took about 2 days total. I used 70-90W if I remember right is what the manual called for.
The manual tells me to fill in a area mid way on the drive there is a small plug on the side ( right side)
and it tells me to fill it up there.
Did I fill it right or do I need to fill it on the side fill hole also?
Thanx
Rob
Thanx
Rob
