Re: changing impellar 115 jonson
what model do you have?
i have an Ocean Runner 1995 115..it is a 60 degree block with OIS ignition, they also made a 115 cross flow 90 degree block
on my 115 you pull a pin and push a rod in... and that takes the connection off the shift rod...you dont need to loosen any bolts!!!!!!!!!!
and you should have it in reverse i think..( the book recomends either forward or reverse, cant remember now) I think it is just easier to see whats going on...the shift rod rises for better viewing...
but you dont have to unbolt any bolts or nuts!!!
i just looked at the evinrude site and believe it or not I cant find it on any of their schematics
but just in case you have a 60 degree motor..it is different than ezekes example... ( even though the action he says, is correct)
If you have the 60 degree motor and cant figure it out, ill take a picture of the page in the book I have at work
bob
