What parts are all needed to to the job? I'm surprised there's no "kit" available with what's needed.
I'd assume the cover would be OK, but what about gaskets, spring, etc.?
I can't be 100% sure as my temp gun was used while rocking in the chop while pointed at the cyl heads but seemed to only go in the 80-90 degree range on the three heads. The tell tale was only luke warm. Would the TT normally be the same temp as the engine or does it not get as hot?
