Boat Doctor1
- Sep 29, 2012
- 123
Merc 4 cyl.- 100 hp. 4 carbs. When running @ idle- indicates a = lean condition- Cannot adjust out-carbs been throughly cleaned & new kits installed. Did same before cleaning all ! Firing on all cylinders.all ok there. This system has the external oiler on side of engine too-serial # = B376687 I am curious as to if something is stopping up a fuel line to the carb/s?? If fuel is induced while running - rpm picks up as expected .Runs fine - after carb s 2 indicate lean again= as lean in cylinder-- anyone experience this before??
