Jolie Lynn
- May 6, 2009
- 66
Just curious,
I have a 1982 Bayliner capri 1950 with Volvo AQ125A, 270 leg and 14X19 prop and wondered if I could get a little more power out of her safely by removing the restrictor plate under the carb. I have done just about everything to get the engine running smooth and reliable. The boat will get to 4500 RPM at 32 MPH with only myself on board. The max RPM is 5000 and max cruise is 4400-4700. Not sure if a lesser pitch prop will help top end...still have wiggle room on RPM's.
Thank you
Thank you
