thisuldoit
- Jul 23, 2006
- 102
I have reached a problem on my carb rebuild. The screw (phillips head) that holds the choke lever on has become stripped. I tried to use a dremel to cut a notch so that I could use a regular screwdriver and that only made it worse Now I have no leverage on the screw what so ever. Should i bend the choke lever so that I can get the choke bowl off and then use pliers to get the screw off, or is the choke lever a hard part to replace?
Suggestions?
Thanks.
Suggestions?
Thanks.
