Engine: 2005 Mercuiser Turn Key Start, Alpha One Gen 2 Drive Serial: 0W356097
Issue: When I accelerate gradually from idle up and onto the plane I hit a dead spot at about 1,400 to 2,000 rpm. The boat literally wants to stop and stall and some times does. If I throttle past this rpm point quickly I don't have this issue at all.
Idle is set at 700rpm and boat doesnt run on at all (used to prior to reducing idle and richening idle mixture).
Timing is fine.
I've got my hands on a carb rebuild kit including float and was wondering if someone could run me through the best way to go about putting the kit through the carb.
Cheers,
Chris
Timing is fine.
Cheers,
Chris
