I've been having an intermittant problem with the motor not starting the past few months. I thought at first, the bendix gear was getting stuck, but after spraying wd-40 numerous times on the shaft, it's more than that. So, I started trying to follow the "outboard won't start" FAQ last night.
My battery is new and has been load tested. I tested both terminals (big and small) on the soleniod, they are getting 12V. Next, i took off the starter and cleaned the starter terminal (it had some corrosion on it). I reattached everything, and then I tested the yellow wire on the starter, and also got 12V.
Now when I turn the key, the soleniod doesn't click. Until today, the motor would start on the first or second pull of the rope. When i tried to pull start the motor today, the rope won't pull out, like its stuck on something. Whats with the rope not pulling, and is the ignition switch the next thing to test? And how do I do that?
