Devil_Inside
- Jun 17, 2007
- 76
Hi there! I have a 1989 Johnson V4 90hp VRO outboard which I bought without the original controls. I have a set of Evinrude controls on my boat which were from an older 60hp outboard that had to be replaced, which I thought about using with the 90hp. Well for the most part it worked - I can operate the throttle and the gear shifter and I also have the idle speed lever, but I cannot figure out the mystery with the choke and the power tilt and trim.
On the motor I have a black relay box which has two sets of connectors - one of them has a rectangular shape and has two leads (red and black), which I assume goes to the power source, and the other connector looks like a half-circle and has five leads (greed, blue, red, black and white) - I think that this connector is used for the power tilt and trim switch (red, blue and green) and the rest of it (black and white) are for the choke, but I am not sure.
Can you please tell me if I am on the right track and help me make this thing work?
