Re: Can a Mercruiser freeze to death in the winter?
Hi Oil Slick, Sometimes a quick freeze down to 10 degrees is okay, but I have had damage to unprotected equipment done at 20 degrees, but usually it is the duration of the freeze that will do the damage. At 15 degrees damage can occur where nothing is broke or cracked, but can cause warping of the cylinder heads and even the cylinders themselves. Also check your outdrive. Some units when left in the up position can collect water in the prop shaft area and break the housing on your lower unit. Been there, Done that, Cha Ching!<br /><br />Some external cracks on the block can be repaired easily by using the lacing method. Years ago I bought a Glassmaster with a cracked block. Used pipe plugs to lace it up. Didn't leak at all and only cost me under 5 bucks.
