72SideWinderSS
- Jul 8, 2006
- 268
I see a lot of questions about " How can I figure out what pitch I have "
Here is one solution :
One way to find the Pitch of an unmarked prop
With your prop sitting on the bench (Prop-nut side up), place a square
from the bench up at the trailing edge of the prop at 5 (five) inches from the centerline of the hub.
Make a mark on the trailing edge of the prop and another mark on the bench, measure the height of the trailing edge and write it down as H1.
Do the same on the leading edge of the prop and write it down as H2.
Now measure the distance between the marks on the bench and write it down as X.
Subtract the Leading edge height (H2) from the Trailing edge height (H1), write it down as Y.
(H2 - H1) = Y
Now divide Y by X, this gives the slope of the line write it down as S.
Y / X = S
Multiply 31.4 By S this will give you approximate pitch.
31.4 * S = pitch
Y / X = S
(5 * 2) * pi = 31.41 (radius * 2) * 3.141 = 31.41
31.4 * S = pitch
(H2 - H1) = Y
Y / X = S
31.4 * S = pitch
Y / X = S
31.4 * S = pitch
