Cajun Boat
samuelfbrown
Recently purchased a Cajun bass boat. It is 1988 vintage. Have a tag saying it was out of Winnsboro,Alabam. Can't find any address or phone.<br />I need a manual to associate myself with the live-wells and wiring.Last owner had a stroke and poor gut can't talk.<br />Also, this boat was in storage about 2 years. Has about 1/2 tank of gas,and since the stuff is so premium now, I hate to pitch it.Also,cannot find tank drain. Will stabilizer (enough) keep me from having trouble if I use this gas?<br />Thanks in advance.Sam
Cal_MI
Re: Cajun Boat
Pump the tank dry and add the old gas to your car's tank. Use new gas on the boat.<br /><br />I remove the motor fitting from the fuel line and start a siphon going with the rubber primer bulb.
quantumleap
Master Chief Petty Officer
Re: Cajun Boat
Get new fuel. Ten or fifteen gallons of fuel is not worth ruining the motor over.
Dhadley
Re: Cajun Boat
And be sure to use the correct octane for whatever motor you have. Im sure a carb job would be in order along with all the normal stuff like a water pump, lower unit oil, etc.<br /><br />Good luck!
