Re: bypass vro pump
First off get your 6 gal tank mixed up with 50:1 premix. Then disconnect the oil line from the vro and cap off the oil line fitting on it. Then find the wiring harness going to the vro and disconnect that and cap it off. Last find the wires coming from the oil tank and disconnect them. Finally, pull the oil tank out of the boat. When you first start it up, let it idle for about 10 min to make sure the 50:1 mix is in the mtr.
