Re: Buzzer by throttle on 1978 Evinrude 115
instead of killing the only life line your motor has, fix the problem. if you replaced the thermostats, check the sender, it is a grounding type system meaning the sender creates the ground to activate the buzzer. if the sender is good, you have a problem in the wires. unless you want to risk meltdown
