Re: Bravo One Vs. Alpha?
A "stroker" is a 383.
I'm not 100% sure, but I believe the recipe is:
A Gen I or Gen II Chev small block 350.
A Crank shaft from a small block 400.
The 400 has a longer stroke than the 350, when you put the 400 crank in the 350, you end up with more displacement and a higher compression ratio.
The higher compression ratio allows you to run a hotter cam, but it means you need to run higher octane fuel.
The extra displacement and compression ratio gives you more torque across the board. I understand they're good setups for boats, as it helps both your hole-shot and your top end.
Personally, I would much rather have a Gen III or GEN IV Chev small block with all original internals.
As far as Alpha VS Bravo, I'd say this:
If you plan to have more than 300 HP, go with the bravo. If you are going to have 300 or less, go with the alpha.
Basically:
Small block --> Alpha
Big block --> Bravo
It seams that heavily modified small blocks running in excess of 300HP (some as high as 350-400 HP) still run okay on alphas. It would appear that Alphas can handle High RPM horsepower, but not HIGH torque HP.
A 383 for example could make 350 HP @ 5400 RPMS. That seams okay on an Alpha.
But, a 454 Might make 350HP @ 4100 RPMS. This is too much torque for an Alpha.
HP = Toque @ RPMS / 5252 So for those examples:
The 383 would be making 340.4 Ft/lbs @ 5400
and
The 454 would be making 448.3 ft/lbs of torque @ 4100
Having said all that, keep in mind that wear = RPMS Squared. All things being equal, you're wearing your drive and engine MUCH faster @ 5400 RPMS than you are at 4100.
