Gentlemen. I picked up a 2002 formula with twin Mercruiser 496 mag engines (I’ll get back with the serial number shortly). Previous owner replaced the trim sending unit with the 2 wire analog pucks vs using the correct wire (Red,white,blue) digital pucks. The analog gauges installed on the boat are not functioning. The two black wires coming from the analog sending unit are not connected to anything, same as the 3 digital wires on engine harness side. Is there a way to get this all working without changing the sending unit out for the correct one?
