Bravo 1 question
ericcarr2000
Ensign
Ok, I am in the process of refinishing my outdrive. Currently i separated the lower from the upper halves, sanded it down and primered it with self etching primer. While having it apart I notice that the shaft that extends up into the upper unit, you can pull out on it just slightly and be able to move it up & down just a tad bit but when you push in on the shaft there is no play in it. Is this normal or is there a bearing in there that needs to be replaced?
alldodge
Yes that is normal, the setting is accomplished by a feeler gauge inserted with the front and measured with a shim special tool. The shaft when installed does not move up under normal unworn conditions
ericcarr2000
Ensign
Ok thanks. I guess I'll move onto reassembling them back together and performing the pressure test on her before I paint her.
ericcarr2000
Ensign
I ordered a seal kit for it but I didn't receive the 2 rubber O-rings that go around the openings between the upper & lower halves. Does anyone know where I can obtain them?
alldodge
ericcarr2000
Ensign
Ok Ill get the serial number for ya tomorrow. Im pretty sure the kit I ordered only had the o rings for the bellhousing though.
ericcarr2000
Ensign
Ok heres my serial number for the drive- OD351140. Where can I get these O-rings from?
ericcarr2000
Ensign
bravo 1 question
My Bravo 1 serial number is- OD351140. I need to replace some of my O rings that are between the upper & lower units. Where can I find these at?
alldodge
Need
O-ring 25-455771 item 3A
Quad ring either 26-36556 (.500 outside diameter) or 26-805344 (.625 outside diameter) item 4
O-ring 25-20826 item 18
You can either google each part placing "Mercruiser" on front of the part number. or go here and order from this site which has the breakdown
http://www.mercruiserparts.com/Show...&inbr=952&bnbr=90&bdesc=GEAR+HOUSING(BRAVO+I)
Also note the O-rings are in packs of 10 for items 3 and 4
