Hello,
Well I have solved my spark issue , now I have a fuel issue.
Motor has 110 PSI TOP , 125 BOTTOM COMPRESSION
Rebuilt carbs/Fuel Pump
New Powerpack , Rectifer
Motor starts and runs
Drop test reveals TOP cylinder running only (110psi)
50:1 mx in a bottle sprayed into carb/cylinder causes motor to perk up when sprayed and while running on TOP cylinder
With top plug disconnected, I can get motor to run on bottom cylinder by feathering the choke plate manually. It has to be just barely open. Seems like it is not getting enough fuel.
I have cleaned carbs and am at a loss....primer bulb gets hard before starting , while running it gets soft.
Adjustments on low speed jet make no difference as I cant keep it running long enough to adjust it. Again, will only run with feathering and manipulating the choke...
Any thoughts/ideas? Thanks!
