royclaypool
- Mar 30, 2017
- 13
Hi guys. Quick rundown.
Bought used 1984 Renken with a Mercruiser 120 2.5l. Original issue was I could only get a good speed for about 5 minutes. Then engine would bog and gas would be boiling in the carb. Engine wouldn't start for a couple hours once this happens. Replaced coil, fuel pump, rebuilt carb, thermostat, throttle cable, water pump/impellar, and battery. While I don't have the same problem, I suspect the problem I have now is related. I can now cruise at WOT for about 30 minutes. Then, engine starts acting funny and temp climbs to about 150-160. After turning engine off, gas vapor was coming out the black tube that connects the carb/air filter and the rocker cover top. The engine ran great for a half hour. My third time at WOT and I'm hooked.
So, what should my next step be? A local boat shop took a peek and said the carb needed to be re-built. Only it already has. Twice. By the previous owner and a friend of mine. Should I just order a brand new carb? Could this issue be related to the little bar that the throttle cable connects to that requires you to loosen the nut on to adjust? Also, temp after turning the engine off reached 170-180. Cause for concern? Any idea's would be amazing.
