Tail_Gunner
- Jan 13, 2006
- 6,237
Were the specs i posted correct for your engine and is it a two stroke?
Thanks Gunner. I've got a couple buds that might be able to hook me up with a prop. probably won't be a 24p solas but it'll be another prop with either 19-21p. I bought the rev4 for 500 or so new but did catch a rouge oyster or something and dinged one of the blades a little.
Anybody interested in letting me borrow a test prop with the flow torque II style hub? I'd pay shipping.
So the pocket tunnel design on my boat is there to bring a column of water up higher then the bottom of the boat. Artificially raising the depth of useable water for the outboard. I guess it could be possible that I'm raising the outboard to much. I did try and look at the anticav plate at different settings. it was hard to see because just forward of the nose of the lower unit the water was being split and splashing all over. maybe by the little anodes on either side. I for sure saw the anticav plate though.
In regards to boat weight. The only numbers I can offer are these.
boat dry weight - 1550
Outboard weight - 500
Full fuel under center console(bottom of boat) - 300
Person onboard(just me in the pic - 170
Batteries, 4 in center console - 300 lbs
Trolling motor and anchor up front - 50
misc items in back of boat pump for power pole etc. - 75
jackplate - 40
power pole and bracket 30
that's about 3000 lbs rounded up. could probably add another 100-200 lbs just for grins.
I've looked online for pictures of various bayboats and their attitudes. Mine seems to be right in line.I'm sure if I put two adults in the rear jump seats I could probably trim it up a little more but I don't run WOT all the time.
