I have a 10,000 lb ABL boat lift and one of the cables has a small kink or fray in the middle of it. I can replace it easy enough but I'm I'm a little hesitant. The stainless 1/4" cable at the hardware store is rated at 1400 lbs. So the cable comes down from the top channel down to a single pulley and back up to a long rod that winds the cable up, thus raising the boat.
There are 4 of these, one on each corner. Am I correct in thinking that each corner is 2 times 1400 lbs = 2800 lbs per corner (because of the pulley). 4 corners times 2800 lbs = 11,200 lbs lift capacity.
Agree or disagree?
There is no help online and I really don't want to pay some lift repairman $$$ for something as simple as replacing a cable.
THX!
Agree or disagree?
THX!
