blackmax 200hp 1989 problems
johno77
Hi,
I am having problems with my mercury 200HP.1989 not 1998
I redid the carbys 2 years ago. The engine has been sitting. I took it out a few weeks ago. I put in fresh fuel and some sea foam. I ran it on the muffs a few times during the week before heading out. Most of the carbon was gone. Not much smoke. Engine ran ok. Little bit hard to start now and then. Went skiing for a couple of hours. Seemed to be good and all rpm.
Sat for a week. When I went to start it again, it would backfire and hard to start. Tried over a few days. Did a sync and link and adjusted idle best I could to workshop manual. When it did go, one of the muffs sounded like it was firing on 5. I noticed the tacometer would go anywhere from 2 - 5 and be erratic / not consistent. I put a timing light on all plugs but did not check the timing. i just wanted to see the consistency of the light. Consistent on all bar 5. It flickered slightly quicker and at one stage the light was just on with no flicker. Then it went back to flicker.
I swapped out switch boxes with other switch boxes I had spare. Engine still seemed like it was running on 5 and rpm tacometer was not consistent.
Do you guys think this could be the trigger or stator? Or idle stabiliser modules?
I've made a dva adaptor. Any tricks to using this?
Thank you
Dukedog
does it have tha 16 or 40 amp stuff on it?
a back fire usually involves timin' in some form or another.. erratic tach usually involves either rectifier and or regulator.. if its a 40 amp motor both will be in one unit... tha big water cooled thingy under tha coils.....
johno77
Thanks for the reply 16amp
Oh and its a 1989 model
Dukedog
yeah, '89 could be either one... if its still got tha idle stab. i'd chunk it... disconnect tha regulator jus for testin'.... i'd start with tha rectifier.. that "should" clear up tha tach problem.... ya need ta test stator and trigger.... back fire would lead me mostly to tha trigger... jmo.
johno77
okay slowly learning the regulator and rectifier are two different things yeah? I just haven't read about them yet in the book I have.
My workshop manual in some parts bit hard to understand its fallen to bits.Is the idle stabilizer on top or on the port side? There's two black boxes that look the same.
Dukedog
tha stab. will have red/white and a black/white wires.. tha rectifier will have 2 yellows, 1 red and 1 gray (tach signal wire).. how many and what color are tha wires comin' outta tha other box
johno77
I get confused easy haha. Ill send a video link hopefully tomorrow .
QBhoy
Think you have sound advice above there. I’d certainly be looking around the main fuse and its holder. I’d also never rule out the carbs either. Despite being cleaned not long ago. Doesn’t mean anything, if there is any doubt around fuel sitting dormant in there for a while.
Learned enough to also never rule out the simple things, like plugs, battery connectors and earths being suspect. Battery too even and any isolators in line.
I take it the oil injection system has been done away with long ago ? Maybe do a compression test to rule out anything nasty. Not likely the case here..she would still start and likely run with no load, if the figures were low..outwith the most serious of situations.
Back to simple things again…fuel line going the right way and not drawing air somewhere? Fitting at each end ok ? Proven the delivery of fuel to the carbs by cracking a drain on the bowls and priming through ? If there is compromised fuel in there and it’s not firing up…the fresh fuel won’t show its face far enough to have an effect for the better. The old fuel could be the cause. Prime the carbs through and see how she’s goes.
That’s what I’d be doing first. Failing a result, time for the more intrusive with the multi meter
johno77
I did some more testing, dva tested trigger, stator ,coils and packs. All tested good apart from trigger low voltage 2.2v.I then removed idle/stabilizer wires and voltage came back up to spec on trigger.
I also did this test(not in the merc manual I have). Hopefully I worded it correct.
I indexed the flywheel placed numbers 1-6 on the flywheel. I placed timing light starting on 1 working my way to six.1-4fine showed up with timing light number 6 was also fine. But On number 5 it showed numbers 3,5and1.
I would assume this is a trigger problem would I be correct?
Engine smokes a lot and backfires on start up. Top of number
5 piston is cleaner then all the rest. I'm guessing because of the erratic timing on 5 it would be backfiring on 5 would I be correct in saying this. Any help much appreciated.
Dukedog
one thing you can do since you suspect #5.. swap tha switch boxes around.. if it stays tha same then it leads to tha trigger.. if it follows then ya have a switch box problem....
johno77
does that involve all the wires including the wires that go to the coils?
Dukedog
yes.. move ALL wires from the inside box to the outside box and ALL wires from outside box to tha inside..... this is just at tha switch boxes only....
QBhoy
I’d maybe guess that you’re getting some sort of cross firing. I’d maybe look towards testing across a few places with a meter. Look for continuity where there shouldn’t be and continuity where there should.
I might even be tempted to get her in a shed or garage…or under cover, turn the lights out/or in the dark of night…open the switch box and run her up. Look for any sparking or shorting out around and in the box. Around the leads etc etc too.
johno77
Thanks Good idea
johno77
Just wondering is there supposed to be continuity between the black ground to red/white? their also continuity from black to single red on the stator
QBhoy
I’d say it’s more important that you don’t have continuity between ground and each of the three stator wires. Should be open circuit there. Testing between each of the three wires to each other, will show continuity I’d think. Unless your set up is different to what I’m familiar with. What exactly do you have from the stator ? 3 wires ? Of what colour ?
johno77
, two blue ,two red, two yellow and one black
