Feeling ambitious I decided to replace my upper crank seal on my '69 40HP. After drilling two 1/16" holes in the seal I threaded two #6 sheetmetal screws into the holes and proceeded to tear the seal to little bits of metal trying to pull it out. Then I resorted to the tactic of wedging a small, thin screwdriver between the outside edge of the seal and the sleeve the seal sits in and carefully crushed the seal all the way around to loosen it up for removal. finally got it out. The rubber portion of the seal seemed to prevent any of the little metal chips from falling down into the cranckase, but if a few did happen to fall in, and with luck not get stuck in the top bearing; what are the chances of them passing out of the engine, or are they going to eventually make their way down to the lower bearing and initiate self destruct sequence? Should I tear down the block? Also, if the new seal is bottomed in the ring, is it too close to the bearing?
