So I got to the issue of my number 5 cylinder no sparky! I pulled the plug out and found a butt-load of melted aluminum all over it! Very dis-heartning. Figured I must of sucked a reed valve. So I tore off the head and found the piston completely covered in melted bits of aluminum. Surprisingly, there is no damage to the cylinder wall. Looking into the cylinder, the fuel air side ports are clean, but alittle debris made it out the exhause side. So I then ripped off the intake manifold keeping the 3 carbs on it so I could see the reed valves. Weird, but all valves are not only present, but they seem to be within specs and still serviceable. What gives? I took the little window cover off the side of the block on the intake side which exposes the side of the piston and the rings are there and appear to be just fine! So what did I suck into the cylinder? Could I have sucked something into the cylinder from the exhaust side? I cleaned off the head already and going to mask off and cover up cyl 1 and 3 and clean off the piston in question. I did a compression check on that cylinder before I tore it down, 3 weeks ago it was 90psi, now it is 76. Anyone know what could of done this?
