I finally got time to install the sterndrive. I have a cherry picker and watched videos that looked like they hooked through the top in the gap on the sterndrive but used the sterndrive lift. Do you use a special hook or is there a better method. I aligned everything already and know I have to rotate prop a little during install. Everything is greased for easy slide. Do you install the round rubber gasket in the bellow or put it on the drive right away? I will be doing it by myself so any suggestions would be great.
