Re: Best Prop for the Money
Take this how you wish, salt or sugar....
In my testing of over 200 props now, I've found the Turbo and Stiletto lines to consistantly perform near or at the top in most situations...Now, let's keep in mind there are about 12 different styles of props between the 2-not counting, but close to that, and as Silvertip said, each application and intended use will be different.
The Stiletto series will cover alot of applications, even in the std Advantage models, and you can add a bit more technology going with a std Turbo1, and in many cases of general boating, this prop is tough to beat.
Turbo also offers a few other models that in most cases of thru-hub props and propper set-up, can't be beat.
Just remember, the application will be the deciding factor as to "how much" technology you need to reach your goal.
