So after a few weeks of trying to remove the flywheel the right way, move on to another idea(which now I realize wasn't so great).
Propped flywheel with a 2X4 on each side running to the ground. Raised boat and basically rested weight of boat and motor and all on the flywheel. Then hit the puller on the top in escense pushing the crankt out of the flywheel.
Well, flywheel came off.
But when I put it back together and I try to spin the motor it has a hard spot each time it spins around. Enough to make the starter not be able to crank. Hard spot is in the same area each time and is apparent even when the plugs are out. Pistons are free, so it's not that.
Any ideas on best way to figure out if I bent the crank or the flywheel? It's not a question of if something was bent but more of what was bent.
