Bayliner capri cuddy fuel tank
harbatinu
I have Bayliner capri cuddy and my tank is leaking. I removed the tank and found hole under the tank. these are the photos of the tank and where the tank was. I want to change it but i didn't find one similar to it. anyone can help me please for what can i do or where to find similar tanks. I prefer it plastic tank
UncleWillie
Re: Bayliner capri cuddy fuel tank
The Manufacturer, Model and Capacity should be molded into the plastic.
Moeller makes Tons of sizes. Looks a lot like a #032529
UncleWillie
Nothing molded into the tank? :confused:
What Year and model is the boat.
"Bayliner Capri" means as much as "Ford Truck". ;)
harbatinu
The photo is to show where is the hole and how much damage the tank :) . Year 1985
MH Hawker
You can all ways contact bayliner,
jestor68
6158.jpg This a 1986 1600 capri cuddy. I bought one (new) in 1986. It did not have a built in tank; it used portable tanks under the splash well. As far as I know none of the 16ft cuddys had a built in tank. The 17 and 19 ft outboard models did have a built in tank.
In 1987, the 16 ft was replaced with a 17 ft, which did have a built in tank. Due to the shape of the transom, I believe that to be a 1987 Capri 1700. Capris had that design from 1987-1989.
Also, note the small "window" on the side of the 1986 1600. The 1987 1700 did not have that "window".
