Stephen Tarry
- Jan 26, 2013
- 9
Hi Guys, I am new to Boats and seem to have dived in really deeply.
I have a Bayliner 2858 with a 6.5 ltre GM Diesel installed, the leg im assured is a "diesel" bravo 3 but not sure of the gearing? She has a 28P Mercury Marine Pitch Duo Prop Photo Attached.
The Engine runs upto 3900-4006rpm before the governor kicks in,but with no load on the prop!
WOT runs at 1800 - 1900 rpm giving a top speed of 10knots??
The engine runs ok! no signs of working hard.
The previous owner had the same problem with speed, but didnt check the fuel lines for blockages? and instead changed the Prop from 22p to the current 28P I have renewed the fuel lines and filter system, and she now starts and runs well sounding like the power is there, when she is opened up the bow lifts out and she feels like she wants to really go? but doesnt get over 10knots.
Bayliner 2585 Magica - YouTube
Its know its easy to asume that replacing the prop will cure the problem but I would like and value your comments, before starting out on an expensive course of action that may not be the right one to take.
The videos are on U Tube under stephen tarry 2858 magica and Bayliner Ciera 2858 Engine Rpm test.
Thanks for reading the above I hope you can help
