shaneb0422
- May 28, 2010
- 83
I just got a new pair of wakeboard bindings, way excited to get out there today and try them out...get my board setup, start the boat prep and realize the battery is dead...well I put it on the charger for about 20 minutes till it was holding 12ish volts...we get to the ramp, launch the boat. It won't start, first crank kills the battery. Okay, I brought jumper cables just in case of that. Brother in law pulls his truck down to the banks, I pull the boat in by hand backwards to get to battery compartment. I hook cables to boat, he hooks them to truck, can't figure out why its sparking so bad....We both have working knowledge of electricity. He's a Project manager and I do Electrical plan review and am an assistant field service engineer. First thing that crosses my mind, as anyone who ever jumps a car is. Put the cables on the proper battery posts.
Well, he doesn't...his truck is running, basically welded the Alligator Clips to the battery posts on both vehicles.
Needless to say, we switched them around and got the boat running....run it around for a while getting a charge going on the battery, I come back towards the shore and try cutting it off and turning it back on to make sure its worth really going out. It won't start. I immediately assume battery is fried, problem is, were about 80 feet from shore. I grab ski rope and docking ropes, tie them together and start swimming. Lame. Battery is trickle charging overnight tonight and I will have it tested in the morning.
Hopefully it's fine, if not, I get to spend 150 bucks in the morning so I can try out my freaking boots I have been waiting 2 days to get into to.
Double check what you are doing...always.
