banshee owner
- Sep 4, 2013
- 227
Re: banshee transom and likely stringers
would you put any glass over it or is that just a waste
WOG on your clamps and the drawing you have im a little confused whats the epoxy in the one picture for.
the other picture you have the clamps installed on the boat do you have the bolt thru the first 2x4 with washer then between the two 2x4 you a washer a nut and another nut the on last 2x4 you have a washer and nut. from the pic it kinda looks like there two nuts between the top of the 2x4 and one in between the bottom part.sorry for the crude drawing but is this more or less what they look like when built
white is 2x4
grey are the bolts
red are washers
grey are nuts
feel free to butcher my drawing so i understand how i build em
when im using them to clamp on the transom am i holding the inside nut on the top to spread it open then tightening the bottom bolt to clamp it down hard.
