I need some more help with my 1956 Johnson 30 RDE18C.
I bought this boat/motor 6 years ago and at that time I purchased and installed new coils, points and condensers and fired it up but never really ran it. I parked it as I planned on restoring the boat someday. Well I've completed the boat and now I'm trying to get the motor running. I rebuilt the carburetor.
It fires good but also back fires and I can't get it to run at start or slow. There is a good ground through the mercury switch all the way to the slow position on the throttle. If I start it in gear with the throttle open a little more it starts and runs but misses.
I checked the point gaps and they're good and from the info I found on here the timing looks good as the scribe mark on the flywheel lines up with the mark on the brass piece behind that rubber wheel.
Any Ideas on what I'm missing or how to make it run slow?
Also there is a wire bundled up under the carb and the other end goes to one of the points. I imagine that was someones kill switch at one time?
Thanks again for your help!!
