Re: Automobile starter for 1998 75HP Force outboard?
Load tested battery at two different locations, both tests passed.
Ran new battery and ground cables- still having same issue.
I removed the plug wires thinking there may be an issue with the ignition timing- still having same issue
I tried removing the spark plugs and the starter stayed engaged with the flywheel and spun it as long as I had the key turned. It seems to work when it doesn't have to deal with the cylinder compression.
As I turn the flywheel (with spark plugs connected) there is approx. 20 degrees of rotation that has a lot of drag, followed by approx. 20 degrees that rotates with relative ease and keeps repeating this pattern. Is this correct? I'm thinking that the bendix is dis-engaging when it gets to the 20 degrees that has less drag.
Please excuse my lack of knowledge on this subject but could the starter be too "weak"?
Sincererly,
At wits END!
