Redrig
Master Chief Petty Officer
- Oct 13, 2009
- 851
Hello All ,
Just this weekend I added a mostly new AC system to my 91 Ford Bronco.
I read as many threads as I could and found alot of good info on the webs , just wanted to have some of you AC pros maybe look over my numbers and give me your thoughts.
by the way , new denso comp , all new hoses and drier , new red orifice tube , flushed condenssor and evap multiple times with proper flush. Vacuumed down to 30hg for an hour , then waited another hour and it stayed at 30hg so no leaks.
Right now , I have about 2.5 cans of 134 in the system (and 8oz oil) charging went like I planned but before I go taking back the gauges I wanted some opinions.
ambient temp 95 outside
low side pressure 42
high side pressure 255 ish
those numbers are at idle and if I give it some gas the high side will creep up to about 280 and that is with my mechanical fan and also a box fan set up in driveway to simulate driving.
engine off and the numbers settle to around 115 each side.
I think the low pressure side is good, it pretty much remains rock steady but is the high side too high ?
its working , but my vent temps could be better IMO , the lowest I have seen is 44F. The pipe where the orifice tube is located is sweating like crazy if that means anything and its nice and cold to the touch.
Question 1 - any thoughts for improvements from the above info?
Question 2 - When I flushed the Evap and Condenser I used an AC flush made for these systems, it had kind of a minty smell. As I mentioned, I flushed blew everything out with compressed air multiple times. Then I vacuumed it down for an hour with the vacuum machine running (30hg) Then I closed the ports to ensure I had no leaks , it stayed right at 30hg for another hour verifying no leaks.
This is where I am concerned, as I mentioned about the smell of the flush , today when I was charging the system in between bottles some of the R134 escaped (just for a second ) and I could smell a little bit of that minty smell in it.
So this is more of a physics question on the vacuum process, I was under the impression that when you take it down to 30hg , it boils off everything in there as a vapor and removes everything , all moisture , air , etc . So why I am I smelling that AC flush in the refrigerent when it was at 30hg for over 2 hours ? shouldnt that all be completely gone ?
Sorry for the book , but I wanted to make sure peeps have all the important info. Thanks in advance
