Re: ATTN STARCRAFT OWNERS: Need advice
back in the day, we had 2 16' Starcraft bowriders with Johnson 55's (one after the other). We are in salt water and kept it moored in the water about 6 months out of the year.
The 55 is a great engine for the boat and IIRC the smallest 3 cylinder (or was it the largest 2 cylinder?) so good power/economy. Didn't have trim/tilt.
However, ours developed leaks at the rivets adn a few weld failures. I'd say this it largely due to salt water, so if you are fresh water, you should be OK. I also felt like the bow would slam hard against choppy water, stressing the hull, but on reflection that could have been softened if we had trim and if I weren't driving them like the 16 year old I was!
So I'd have to agree with the others, and you have the right attitude: assume it leaks and assume it doesn't run.
