Re: at lake motor want run HELP
Not enough information to be accurate as to if the Seafoam is causing an issue. So, having said that, it's best to start at the very top. Compression Test/Spark Test/Fuel System check. Most older carbs need maintenance and occassional rebuilds which are simple to do. Also, concerning the fuel system; a lot of the older outboard fuel lines where not build with Ethanol in mind, so they are deteriorating and causing issues. Might be a good time to check the fuel line all the way from the carbs out to the tank itself.
Why did you decide to do the Seafoam, or was it something you consider normal routine?
