Arabian Stringers.
Tahorover
I'm a few weeks away from starting a stringer replacement on my 74 Arabian. The stringers are huge compared to most I see here.
Anybody done stringers on a Arabian 200 before?
rickryder
Re: Arabian Stringers.
I would guess that's a 20' boat.... I'm doing a Four Winns 210 My stringers were 11" tall 17' long
rickryder
6" wide! Those aren't stringers there Anthony power beams! :D
arabian 200
Nice project! I replaced the stringers in my 79 arabian. Mine being the sterndrive model my stringers were a lot shorter than yours also not as wide, mine were 12x2 x7'. I pulled the engine,every thing else was out of my way. The foam century used to add flotation was the the most difficult part to remove and replace,have to be careful not to put too much foam in holes (over expanded and blew out plywood pieces for the floor, took two days to fix this) otherwise a fun project
arabian 200
Hey tahorover have you started your stringer replacement yet. I am curious about how it is going
Tahorover
I put it on the back burner and removed all the hardware from my Gar Wood and started a re-finish job.
attachment.php
