I recently changed the rotation on my AQ225E w/275 drive to try a righthand 4 blade prop which I obtained. I've noticed that after the rotation change, the unit now raises in reverse. Is it possible that by changing the linkage to change rotation it now is by-passing the reverse lockout mechanism? Is there another linkage or something else that needs to be changed, other than the one linkage inside the transmission cover?
