Im finishing up a project boat 19.5 cuddy. Its got an aq131a in it. It had a 275 outdrive but had alot of corrosion. I picked up a second motor and outdrive 125a 270. I was planning on using the 270 everything will bolt up but i hit a snag on the prop. The 275 had a right hand prop the 270 has a left hand prop. I understand these drives will go both ways but is there a reason the 275 was right hand. I thought most vp drives used left hand. Both drive where from single drive boats.
Also with the 270 is it better to to run one way verse the other?
