Had a 28' Playcraft bought last year. Came with a 48hp Evinrude and I was sick of ONLY being able to troll slowly. I bought a 115hp outboard used from a guy for about $400 and got it running GREAT. I mounted it up last weekend and put new cables on. Motor mounted very easily and fits perfect. Tag of the boat says, Max HP 120 so I know I should be OK there.
My question starts here though. I took it out and launched it for the first time with different motor on it tonight and took it for a ride around the lake. Ran great. Gained about 10 to 15 more MPH on the water. Bounced up from 14-17mph with the old motor up to 23-30 with the new one...thats pretty good I think for a 28' pontoon. But, here goes the problems...
The only way I can run it is with the trim all the way down. If I trim it up, it revs up the RPMs and acts like it isnt pushing any water and then it bogs it down and take hold and sets you in your seat and then slips out again. Im curious of a few things....
No. 1: Would a whale tail help this out by holding the water down around the prop?
No. 2: Would the fact that there is NO Zinc/Anode trim tab or what ever it is called right behind the prop cause that problem? OR....
No. 3: Could it be possible that I should have gone with the EX-Long shaft to drop the prop deeper in the water?
If anyone has any other good ideas for me....Im all ears. I think I am going to get a "whaletail" on it and of course a trim tab and see if that helps or not. I will say this though....when it was peged and running full out, it ran great, never skipped or nothing. And if you were at a stand still in the water and dropped the hammer on it....the hole shot was pretty good for that big of a boat. It would usually skip out of the water once and rev up but then grab again and take off from there and hold good.
Thanks for your time!!!
