stancalame
- May 10, 2014
- 113
I have a 1991 OMC 547APERGD WITH CONE CLUTCH KING COBRA OUTDRIVE and this is all related to another thread I have regarding difficulty not shifting out of forward into neutral. I am working to insure my idle speed is in the 450-500 RPM range as sepcified. I'm preparing to turn my carburetor and check engine RPM. Bought an "apparent" gently used Sears dwell/ tach tachometer from a local guy on Craigslist and purchased new vacuum/pressure gauge for tuning carb properly.
I know I need to connect vacuum gauge to full intake vacuum and I hope it's obvious where I can connect or tee into a line. Once engine is warmed, can I disconnect or tee into the vacuum line that is on bottom of carb that is connected to the choke diaphragm and get full vacuum? See photo.
Carb is Holley 650, 4175 spreadbore. New kit in it 2 years.
If not there, then where?
