jamespjackson95
- Jan 21, 2012
- 30
Hey guys, I want some help diagnosing a boat. The boat is a 2000 with a 5.7 mag mpi 5.7. It came into my shop and it was said to be running fine. The customer wanted the water pump impeller, and the battery cable connections replaced (they were corodded bad). Anyways I changed the impeller and the cable ends and started the boat up on the hose to ensure it was still pumping water fine. It was pumping water great. I let the boat idle for a while and then gave it a little throttle in neutral. At approx 4k rpms, the engine sort of skips. (the tach did not work, this is just a rough guess) It doesnt backfire, or doesn't shut off, just kind of skips... sort of like its missing. So i called the customer and told him and i tried doing a tune up. Replaced the plugs first with no change, replaced the dist cap and rotor with a sierra kit from west marine. Also did plug wires. When i first started the boat up it idled fine... when giving it throttle to see if it skips, the boat beeps 3 times, 1 second beep, 2 seconds off, 1 second beep, 2 seconds off etc.... the boat would only do this at higher rpms (approx 2k), it would not do the beeping while idling, and the boat would still skip at approx 4k rpm, just like before... so i then checked the fuel filter (separator) and it had a lot of what looked like muddy water in it... i dumped it all out and then installed it without filling with gas.... the boat started and immediatly beeped like before at idle, and then shut off after about 10 seconds. I went and bought a new fuel filter and installed full of gas.... now it only beeps at 2k rpm like before... it does not beep at idle.... gear lube reservior is full... when i changed the impeller i pumped gear lube in the bottom untill i saw it come out the top hole, then put the plugs back on.
Any input here guys? Want to check out some simple things before i fork out money for the scan tool.
