In continuance of an older topic titled Volvo steering arm removal
I need to get the gimbal ring off because I need to sandblast and paint it. I screwed the three screws off at the bottom, bought the 9/16" bolt and a big washer according to the descriptions above. What happened to me was that I destroyed the threads on the 9/16 bolt, and it slips off. The steering arm has moved a bit however.
What am I doing wrong?Is there anything else besides the three bolts under the outdrive, which needs to be removed? Does anyhting needs to be removed from the inside?
Thanks for all help
Thanks for all help
